tomb7us
Chemical
- Feb 21, 2008
- 9
I have a question that ive been pondering. How does sugars and fats influence conductivity in water. Basically we have a process here where we run 30% solids milk through an evaporator and separate the milk and water to 60% solids.
What happens is we have carryover of milk into the water exit stream (cow water). Right now we have been measuring conductivity, and pH to get a basis of water quality and the conductivity ranges was 15-20 (micro Siemens i think is the units) down to 2-8 with a separator pressure change. But how does sugar and milk influence your readings on conductivity (we run sweetened milk through the evaporator).
Second is conductivity a good measure to use for water quality given what we are separating (we are trying to clean up the water to use it elsewhere since the milk causes build up and slime later on).
We just sent samples to be measured for turbidity and im trying to swing corporate to buy a hand held.
