What are the best practices for visually witnessing a boiler hydrostatic test? If the boiler hydrostatic test must be visually inspected from inside the firebox for tube leaks, the confined space entry is not technically zero energy. I could see a practice where the boiler is brought up to 1.5x pressure and held for a time, and if no drop in pressure you can assume no leakage, and then make entry to visually inspect the tubes. However, you still don't have zero energy.
-Mike
-Mike
