davidbeach
- Mar 13, 2003
- 9,529
Historically we've stepped down from transmission/sub-transmission to distribution voltages with delta-wye transformers with the low-side wye solidly grounded. Worked great for decades. Still works great for much of the system.
But, we're seeing increasing amounts of distribution connected generations, mostly PV, on some of the more rural portions of the system. Enough in some cases that once it's all built the distribution system will become a source feeding the transmission. Now those delta windings begin to become a liability in that they don't provide an effectively grounded source to the transmission. We're adding 59N protection to trip the transformers if they are feeding a ground fault on the transmission system.
An effectively grounded source would be highly desirable. The most straightforward way of getting there, while also maintaining an effectively grounded source for the distribution would be to replace the delta-wye transformer with a wye-delta-wye transformer. Many advantages in doing so.
One huge disadvantage though, feeders need to be capable of being tied to adjacent feeders and the 30 degree phase difference between a feeder sourced by a wye-delta-wye and a feeder sourced by a delta-wye makes it difficult to tie the feeders together.
What I want seems to be a purple flying cow, aka a wye-delta-wye where the low side lags the high side by 30 degrees; they just don't seem to be stock items. ;-)
Can a wye-delta-wye ish transformer be wound with a bit of zig and/or zag and provide a 30 degree shift while still having decent ground performance? Is that something that scales up to 16.8MVA (self cooled rating) with primary voltages up to 115kV? I know various manufacturers make harmonic cancelling transformers with all sorts of weird phase shifts zigging part of one winding and zagging part of a different winding, but at sizes two orders of magnitude smaller and voltages over 2 orders of magnitude lower.
Are there distribution level (13kV or so) phase shifting devices that could sit at the boundary between the two phase angles and allow tying the two sides together?
Has anybody else had to deal with this type of situation? How did you solve it?
