Conical head
FFEA
AR
I need to model a 4m diameter 60° conical head with a 2in nozzle on the vertex. How can I do it in compress? Please help. Thanks!
Federico,
This is a pretty crazy cone. I would suggest not taking this route and to use a head with a nozzle coming out of it.
Also, one thing to note is that since your angle is greater than 30 degrees, you would fall under UW-12 type 8 and the design falls outside the normal instruction of ASME Section VIII.
Anyway, to answer your question. In the transition menu, set the large end diameter to 4 meters, the small end diameter to 2.375"
To calculate the length, you take the ((Major OD-Minor OD)/2)/(tan(angle)). This would be ((157.5" - 2.375")/2)/tan (60) which gets you about 45". You can check your work in the details on the right tab at the bottom.
Hope this helps.
Thanks for your answer Afox!
I will consider using another kind of head.
In any case, does Compress provide a tool for modelling conical heads? Because a transition with small end diameter = 0 is not an option.
I don't think Compress has the ability to model a cone that ends at a point. You could make a cone that ends at whatever Od, and then put a flat plate at the end of it.
Also to clarify my previous post, I would suggest an elliptical head with a nozzle coming out of the center.
