Hey guys,
I build a Bounding Box depending on the user's input. When I do it in the NX GUI the toolingbox has the selected parent objects in the information window, but with the one i created in NX Open, there are no parents visible.
Do you know how I can fix that? I am working with the Blocksytler to let the user select the objects. (see code snippet below)
After that i want to create a CSYS that's in the middle of the bounding box. And that is associatively connected. Do oyu know how?
The aim is to change or move the body, on which the bounding box is built on and the bounding box should change and move with it too, and also the CSYS.
Code:
Public Function CreateBoundingCylinder(ByVal selectionObj As BlockStyler.SelectObject, ByVal vectorAxis As BlockStyler.SpecifyVector) As Features.ToolingBox
workPart = theSession.Parts.Work
Dim nullNXOpen_Features_ToolingBox As NXOpen.Features.ToolingBox = Nothing
Dim toolingBoxBuilder1 As NXOpen.Features.ToolingBoxBuilder = Nothing
toolingBoxBuilder1 = workPart.Features.ToolingFeatureCollection.CreateToolingBoxBuilder(nullNXOpen_Features_ToolingBox)
toolingBoxBuilder1.Type = NXOpen.Features.ToolingBoxBuilder.Types.BoundedCylinder 'weitere Auswahlmöglichkeiten: CenterAndLengths, BoundedBlock
Dim selectedObjects As NXOpen.TaggedObject() = selectionObj.GetSelectedObjects
Dim numObjects As Integer = selectedObjects.Length - 1
'Alle Parts müssen geladen werden, dass die Toolingbox erstellt werdne kann
For j As Integer = 0 To numObjects
Dim theObject As NXOpen.NXObject = selectedObjects(j)
Dim thePart As Part = theObject.Prototype.OwningPart
thePart.LoadThisPartFully()
Next
Dim bodyDR1(numObjects) As NXOpen.BodyDumbRule
Dim bodyDumbRule1 As NXOpen.BodyDumbRule = Nothing
Dim bodies1(0) As NXOpen.Body
Dim faceDR1(numObjects) As NXOpen.FaceDumbRule
Dim faceDumbRule1 As NXOpen.FaceDumbRule = Nothing
Dim faces1(0) As NXOpen.Face
Dim edgeDR1(numObjects) As NXOpen.EdgeDumbRule
Dim edgeDumbRule1 As NXOpen.EdgeDumbRule = Nothing
Dim edges1(0) As NXOpen.Edge
Dim rules1(numObjects) As NXOpen.SelectionIntentRule
For k As Integer = 0 To numObjects
If selectedObjects(k).GetType.ToString = "NXOpen.Body" Then 'Body
Dim theBody As NXOpen.Body = CType(selectedObjects(k), NXOpen.Body)
bodies1(0) = theBody
rules1(k) = workPart.ScRuleFactory.CreateRuleBodyDumb(bodies1)
ElseIf selectedObjects(k).GetType.ToString = "NXOpen.Face" Then ' Face
Dim theFace As NXOpen.Face = CType(selectedObjects(k), NXOpen.Face)
faces1(0) = theFace
rules1(k) = workPart.ScRuleFactory.CreateRuleFaceDumb(faces1)
Else 'Edge
Dim theEdge As NXOpen.Edge = CType(selectedObjects(k), NXOpen.Edge)
edges1(0) = theEdge
rules1(k) = workPart.ScRuleFactory.CreateRuleEdgeDumb(edges1)
End If
Next k
Dim origin1 As NXOpen.Point3d = Nothing 'der Punkt ist nicht wichtig für die toolingBox Erzeugung, muss aber für die direction angelegt werden
Dim vector1 As NXOpen.Vector3d = vectorAxis.Vector 'wird auch im BlockStyler ausgewählt
Dim direction1 As NXOpen.Direction = Nothing
direction1 = workPart.Directions.CreateDirection(origin1, vector1, NXOpen.SmartObject.UpdateOption.WithinModeling)
toolingBoxBuilder1.AxisVector = direction1
Dim unit1 As NXOpen.Unit = Nothing
unit1 = toolingBoxBuilder1.ZValue.Units
Dim expression1 As NXOpen.Expression = Nothing
expression1 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim scCollector1 As NXOpen.ScCollector = Nothing
scCollector1 = toolingBoxBuilder1.BoundedObject
scCollector1.ReplaceRules(rules1, False)
Dim selections1(0) As NXOpen.NXObject
If selectedObjects(numObjects).GetType.ToString = "NXOpen.Body" Then 'Body
Dim lastBody As NXOpen.Body = CType(selectedObjects(numObjects), NXOpen.Body)
selections1(0) = lastBody
ElseIf selectedObjects(numObjects).GetType.ToString = "NXOpen.Face" Then ' Face
Dim lastFace As NXOpen.Face = CType(selectedObjects(numObjects), NXOpen.Face)
selections1(0) = lastFace
Else 'Edge
Dim lastEdge As NXOpen.Edge = CType(selectedObjects(numObjects), NXOpen.Edge)
selections1(0) = lastEdge
End If
Dim deselections1(-1) As NXOpen.NXObject
toolingBoxBuilder1.SetSelectedOccurrences(selections1, deselections1)
Dim selectNXObjectList1 As NXOpen.SelectNXObjectList = Nothing
selectNXObjectList1 = toolingBoxBuilder1.FacetBodies
Dim objects1(-1) As NXOpen.NXObject
Dim added1 As Boolean = Nothing
added1 = selectNXObjectList1.Add(objects1)
toolingBoxBuilder1.CalculateBoxSize()
toolingBoxBuilder1.ShowDimension() = True
Dim nXObject1 As NXOpen.NXObject = Nothing
nXObject1 = toolingBoxBuilder1.Commit()
Dim expression2 As NXOpen.Expression = toolingBoxBuilder1.OffsetPositiveZ
'work with the box that's created by the toolingboxBuilder
boundedBody = toolingBoxBuilder1.GetObject
'listOfBoundedFaces = boundedBody.GetFaces() 'returns the faces created by the feature
Dim toolingBoxFeature As NXOpen.Features.BodyFeature = CType(boundedBody, NXOpen.Features.BodyFeature)
Dim toolingBoxBodies() As NXOpen.Body = toolingBoxFeature.GetBodies() 'sammelt die Körper, die durch das Feature erzeugt wurden. Hier nur einer.
'DimensionOutput(toolingBoxBodies(0))
'legt eine Änderung der Darstellung eines DisplayableObjects an
Dim displayModification1 As NXOpen.DisplayModification = Nothing
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = True
displayModification1.ApplyToOwningParts = False
displayModification1.NewTranslucency = 40 '0 entspricht komplett undurchsichtig und 100 entspricht komplett durchsichtig
Dim obj1(0) As NXOpen.DisplayableObject 'hier wird das Objekt angelegt, auf das die Änderung angewandt werden soll
Dim boxBody As NXOpen.Body = CType(toolingBoxBodies(0), Body)
obj1(0) = boxBody
displayModification1.Apply(obj1)
displayModification1.Dispose()
toolingBoxBuilder1.Destroy()
workPart.Expressions.Delete(expression1)
End Function
