liam1369
- Nov 13, 2014
- 73
Afternoon all,
I have a general query in relation to some detailing for a goal post column that fixes to an existing block work flanking wall. The column has been inserted to take the load to a separate eccentric foundation, as opposed to loading the existing inner skin of blockwork. However, I have advised to provide fixings to laterally restrain the column.
The contractor has come back and said he usually just uses screw fixings or resin fixings without slotted holes? I would assume best practice would be to provide circa 20-30mm slotted holes as per attached which ensures that none of the loading from the column loads the wall in anyway, however, still allows restraint laterally.
Does anyone have any experience with this? - They do not seem to keen on the slotted holes, however, I am being quite firm for the time being.
Thanks for any help.
I have attached some other useful snippets. Please let me know if you require any further details but the attached sketch should hopefully make sense.
