connection analysis for a bolt using beam probe data from ANSYS (moment in particular)
Max1989
CA
thread507-474378: Bolt Analysis with results coming from ANSYS
I have a question about how to use beam probe data to conduct connection failure analysis? I know how to get the normal and shear stresses due to the axial force and shear force. Also, I know how to obtain the shear stress due to the torque. However, the bending moment is a bit unclear to me. Please take a look at the model below.
It is a 2-part flange assembly. The end of the pipe is fixed rigidly. There are four beam connections connecting the two parts together. The beams are scoped to the imprint of washers.
A frictionless contact has been defined between two parts. There is an external remote force of 1000N in the x direction, scoped to the surface in red (see below).
Large Deformation is on, and the beam probe data is shown below.
as you can see, the bending moments at I and J are quite different (6372 and 687). If I use the higher moment value(6372) and calculate the bending stress for an M10 bolt, the bending stress will be 649MPa. Is that number reliable? That means yield of my A4-80 bolts. Such a high moment could be interpreted given the image shown below: Due to the debonding, the force is applied through only a portion of the original scoped area, causing a large moment at the end of the beam.
then, I added a pretension of 2100N and ran the simulation. the bending moments are still large (4220 and 1854). By the way, when I add a pretension and run it, the reported values at J are for midlength of the beam. Hence, it makes sense that the moment values at end of the beam (I) is different from that of the middle (J).
why apply these moments to the bolt ? Isn't the bolt modelled as an endload element ??
