connectors
vinod68
Chemical
Jun 22, 2003
21
hi !
could you guys help me source connectors / terminal blocks for two core wire 2.5mm2 (10 amps) for single phase motors having two clip type lug connections and from the power source the wire will be having two pin type lug connection.
The connector will be mounted on a sheet metal frame with screws passing through the connector.
thanks
i tried southco usa but they do not make these connectors.
i can send an image file if required.
