Actually I was meaning by transmission voltage shock. But I can see that may not apply to road work. Dump trucks that rise the beds under the lines, yes it happens too often. Or even trash trucks.
Bigger issue is they drive off and don't report it, and we have to find out by other means.
Also construction dig in's after the line is marked. Why do we bother marking them if it is to be ignored?
But then again, I have also seen the same with water and gas lines.
Someone digging into a sewer line is it's own reward.
On that same subject, I have seen distribution lines crossing the highway with several splices (not an easy thing for ACSR conductor). The lines meet code, so how did this happen?
