I would appreciate it if someone could give me advice regarding constraint requirements in sol101 contact body analysis. So I have a rectangular plate clamped around its edges. An unconstrained cylinder is pushing down on it using a force card. Contact bodies have been defined. Is that sufficient or does the cylinder require minimal constraints to avoid rigid body motion is sol101? Currently the f06 shows that the model is running but isn't converging i.e. keeps stating detection of node penetration and continues iterating. So I have to abort the job everytime.
Is this a sign of an unconstrained body?
Thanks in advance.
Thanks in advance.
