Control valve sizing: Xt value
im_danl
Chemical
Venezuela
Hello everyone!
I'm trying to do the design of a pipe system, and right now I'm struggling with the sizing of the control valve that my system it's going to use. (I've never done this before)
I've been trying to follow the sizing formulas used in the ISA 75.01 (Flow equations for Sizing Control Valves) and also getting some guidance from the Valve Sizing Handbooks from Baker Hughes and Emerson, but in general, the formulas are pretty much the same in all of those.
The problem that I'm facing right now it's a specific value called 'xT' that denotes the 'terminal pressure drop ratio', basically the point of the pressure drop ratio at which the flow starts to be considered critical.
This value it's supposed to be supplied by the control valve's manufacturers in their product sheets or something like that, but I've searching through all the resource center from Baker Hughes and Emerson webpages and couldn't find a single xT value, at least not for Globe Valves. Where do you guys find those? Is it a detailed value that you'll only get after doing a quotation or something like that? If so, how I'm supposed to size my valve before asking for a quotation?
That's pretty much what I'm struggling for with this formula, because every other variable it's related to my fluid properties and my process conditions, but that xT it's a external value.
Thank you in advance for your help, Daniel.
The values of XT should be determined by air test by the manufacturer of CV. However, typical values are given in Table 2 of ISA 75.01.
One has to contact the manufacturer for their specific data.
There are values for Xc ( which sound the same as the Xt you are looking for, given the definition of Xc ) in the chapter on Instrumentation-subsection on control valves, in the GPSA for globe, butterfly and ball type valves
For Fisher valves their "Catalog 12" is pretty exhaustive, some vendors aren't as good at providing these in generalized cuts and you have to engage them for a quote/data sheet with a application/sales engineer.
I understand, so basically in order to get specific values I'll probably have to make some contact with the manufacturers. I guess I'll stick with Table D.2 meanwhile, since I'm doing kind of a preliminary sizing.
Thank you for your answers! :)
Search the internet for the Valmet Flow Control Manual. Pg 70 explains Xt. You can download for free. Also download the control valve sizing coefficients book from Valmet. There are pages of various valve types and the Xt values are in the tables for each valve type.
Here is an extension to Fishers cat 12 it has all the Cv & Xt values listed.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.emerson.com/documents/automation/product-data-sheet-catalog-12-section-1-sept-2017-fisher-en-122394.pdf
However I will also say that for years and years we designed cage style valves in =%, Linear & 1-5 stage low noise with high accuracy long before Xt values were introduced simply by working out the summation of the body, cage & seat bore Cv's individually to come up with an overall Cv. With all that being said I've see the Xt in action to some extent on Fisher whisper III cages but working out the sizing it still falls within +/- 5% accuracy so long as the listed Xt is not below 0.65 however many of the Whisper III vortex step drilled (A3/B3/C3/D3) have an Xt of 0.5 or less which makes a big impact on calculated Cv.
