C26M13
Chemical
- Oct 2, 2015
- 73
I am looking for some good reference to get better understanding in the use of Temperature Control Valve and Pressure Control Valve.
I am not really sure how is the function of the TCV and PCV in controlling the flow through a pipe.
I want to ask any help from you to give me some feedback regarding the concept of control valve maximum flow. My question is, if there is a trip upstream of the control valve and the control valve are in fully open position (see attached sketch).
Can TCV limit the flow to PCV (in other words the max flow to PCV depends on the valve Cv of TCV or not) i.e. the max flow through TCV when fully open (Valve Cv: Wide Open) is 500 kg/h.
Is the max flow to PCV also 500 kg/h or the max flow of PCV should be different (Fluid type: Gas)?
In this case, as per "API 521 4.4.8.3 Inlet Control Devices and Bypass Valves" how to determine the flowrate of the control valves?
Many Thanks,
Many Thanks,
