Pelotoner2
We are seeing many VE contractors entering the scene to VE our deep foundation designs. Some of these are design-build with varying augercast pile sizes, or other deep foundation system, which are an in-kind exchange.
However, we just heard about a VE request to move from augercast piles (+/- 120 ton compression) to Controlled Modulus Columns (CMC) on a building. While we've entertained CMC in poor soils, debris areas, and heavy low-rise buildings, this request is for a 16+ story, concrete two-way flat plate, relatively heavy building.
It's also a moderately small footprint, where overturning is an important consideration.
Further, all of the lateral capacity will be taken by soil-interaction friction between the footing and the load-transfer platform (although passive pressure could be used, I would be hesitant due to the large movement required for full passive activation).
I would also be concerned about overall and differential settlement. CMC's bear into a shallower layer and due to the typical quantity of CMCs, partially act like a field of group-action piles.
Although this isn't a project for which we are EOR, I'm sure this will come up on one of my projects in the future. As of now, I would provide extreme resistance to this system for this size/weight building and would consider resigning as Structural-EOR if backed into a corner. I'm curious about other structural engineer's thoughts and experiences.
