MuhammadHasan
- Aug 30, 2023
- 1
Hi, I have modeled beams that are supported on columns with offset from CG of the column section. I have connected the beams with rigid link to the C.G of the column.
When I tried to run it showed the following error please help me to solve the problem.
The structure is G+2 residential building with only static analysis.
