saja11
Bioengineer
- Aug 2, 2019
- 42
I have a knee joint model which needs to be simulated with Fibril reinforced poro elastic material properties. The model run fine with stiffer material properties but when i run the model with soft material properties (resembling human cartilage tissue), I can these convergence errors. Can someone suggest what I need to change in .inp file for this model? (I need to make changes in .inp file as I don't have access to .cae file)
Message file includes:
***WARNING: EXCESSIVE DISTORTION AT A TOTAL OF 2 INTEGRATION POINTS IN SOLID
(CONTINUUM) ELEMENTS
***NOTE: ELEMENTS ARE DISTORTING EXCESSIVELY. CONVERGENCE IS JUDGED UNLIKELY.
***ERROR: TIME INCREMENT REQUIRED IS LESS THAN THE MINIMUM SPECIFIED
***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT
ELEMENT PART2.9186 IS DISTORTING EXCESSIVELY.
***ERROR: THE ANALYSIS HAS BEEN TERMINATED DUE TO PREVIOUS ERRORS. OUTPUT FOR
THE LAST CONVERGED INCREMENT HAS NOT BEEN WRITTEN DUE TO CONVERGENCE
ISSUES.
ISSUES.
