Lowrentstuff
Computer
Background Story:
I'm looking for a control valve that can control the stream to the desired flow. What I found in the domestic market are mostly Actuator valves, an On-Off type valve. I asked some sellers if it is possible to make that actuator to control the stream flow (like with 25%, 50%, 75%, or 100% opening), and then some said yes, while others said no. They said it's possible just by adding a positioner. But I have my doubts.
The Question:
- Is it possible to convert the On-Off valve into a Control valve?
- Does the actuator in the control valve and the on-off valve have different assemblies?
- How can adding a positioner would help?
The Question:
