Pfairview117
Is there any logic in saying that if a sprinkler system was designed to provide 0.18 gpm/sq.ft. over 2,000 sq.ft., than it could deliver a higher density over a smaller density such as 0.2 gpm/sqft over 1,500 sq.ft. Since less sprinklers would operate in the smaller area, would they each receive higher pressure resulting in higher flow/higher density?
Or is the area chosen completely separate from the design density.
