LTWayne
Chemical
- Apr 21, 2020
- 2
I have an existing pump for naphtha service (aka Pump 2) with the following specs:
Suction P: 80.2 kPag rated, 86 kPag actual, 399.9 kPag max per spec sheet
Capacity: 178 m3/h rated
Diff head: 1164 kPa
Suction elevation: 0.78 m
The pump has a minimum flow spillback line controlled by an FIC right at the discharge of the pump (max 90 m3/h flow).
The pump has a S&T heat exchanger (hot side, dP at ~69 kPa) at the suction whose inlet and outlet piping rises to 9.6 meters and at that point the service fluid flashes due to the pressure being lower (120 kPag) than its vapor pressure at 167 kPag.
To solve this issue, I plan to route the naphtha first to another pump (aka Pump 1) to increase its pressure before routing this to the heat exchanger. The expected pressure at Pump 2 suction would be at ~224 kPag. The specs of Pump 1 are the following:
Suction P: 140 kPag rated, ~170 kPag actual
Capacity: 155.39 m3/h rated
Diff P: 137 kPa
Shutoff diff P: 180 kPa
Suction elevation: 0.53 m
Are there any other considerations that I need to check? What could possibly go wrong with this kind of setup?
Thanks!
Diff head: 1164 kPa
Diff P: 137 kPa
Thanks!
