DoubleStud
If I convert a window well into a full height door and add retaining wall and stairs (direct basement access from exterior), how do you avoid cold bridges? The footing of the basement is no longer buried to frost depth.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
XR250 said:Is 3 ft. of linear exposure really going to cause a frost heave issue? There is probably enough surrounding heat to mitigate this.
