AO1958
Industrial
- Mar 13, 2009
- 73
Hello there
I am facing to following topic.
Very specific, and old post can't help me, unfortunately.
I am dealing with a cooling coil, and volumetric air flow at OUTLET is given to me.
Known data are:
- air inlet temperature
- air inlet relative humidity
- coil capacity
It is a strange problem:
- since air I estimate there will be dehumidification I assume mass flow won't conserve.
Therefore I can't calculate air outlet mass flow and consider it constant.
Any suggestion of how determining inlet volumetric air flow ?
Many thanks !
Known data are:
- coil capacity
Many thanks !
