Cooling down of atm HCl from -60°C to -30°C
peter Hond
Chemical
Feb 22, 2023
7
Dear
I would like to calculate how much meters of pipeline it takes to cool down HCl from -60°C to -30 °C in a pipeline using only air flow around it.
The flow of HCl through the pipeline is 30000 kg/u.
I took 3 m/s of wind at 20 °C.
The pipeline is made of uninsulated stainless steel and is 4'' in diameter with a thickness of 1,4 mm.
Thanks it advance!
The medium in the pipeline is at atmospheric conditions 1,013 bara.
To support your calculation, consider the paper attached. You can easily develop a spreadsheet using the relations included in the document.
I've some doubt about the quantity you want to heat in a 4" pipe. Is it 30 tons/hour?
Pierre
 https://files.engineering.com/getfile.aspx?folder=68de0792-468d-459b-90e5-8ee03277b2c4&file=heat_transfer_model_for_above_or_underground_insulated_pipe.pdf
@peter, if this is a real world problem then you have more things to consider than basic heat transfer as provided by Pierreick (very nice though). The air will have water and at -60ºC surface temperature you are going to see a massive ice cape form around the pipe. This ice will insulate the pipe and thus reduce the heat transfer. Thinking back to my heat transfer classes in uni i think i remember that there is a way to approximate the ice thickness and then the insulating effect.
--- Best regards, Morten Andersen
