I have a 16 inches (outside diameter)chilled water pipeline (carbon steel) that is 20 feet long. Water is flowing through it with an initial temp of 1 degC. The line is exposed to an air temperature of 40 DegC and I would like to know the temperature at the end of the pipeline. The flow rate is 2000L/Hr.
I'm trying to generate some kind of pipeline heat gain table using the exposed pipe.
Can anybody helps
Can anybody helps
