BLee_PE
- Jun 1, 2023
- 2
Has anyone done or seen a cooling tower yard installed on grade with no framing to raise it? I've got a GC asking if it's possible to get one piped up if it's sitting directly on a pad.
I am good to go on the pump NPSH since my chillers are located in somewhat of a basement. So the on-grade elevation of my cooling towers is ~10 feet above my condenser pumps.
Anyways, I am struggling to understand how all the piping and controls elements will fit together. On frame mounted towers you will see a lot of pipes and valves ran beneath the chillers. I won't really be able to do that.
