Smoothcriminal
Chemical
Cooling tower pump keeps turning OFF and giving an object error.
This has happened 10 times since 7/5.
When the pump shuts off, there is reduced flow to the chiller condensers with potential protective shutdown of the chillers.
When the pump shuts off, there is significant water leakage from the shaft packings and a considerable volume of water is spilled on the pump room floor. Prior of this happening, we have been observing that the cooling tower pump discharge pressure has a very long response time to pressure changes, which indicates a fouled sensing line.
Any ideas on how to troubleshoot this issue?
