Hi, I am designing a hydraulic cylinder to comply with European pressure vessel code EN 13445.
The sealing casing will if possible be of copper-aluminium alloy EN1982 CC333G. The seal and casing is subjected to the internal pressure.
I can not find CC333G or any other copper-aluminium alloy in EN 13445. There is another standard EN 1653 "Copper and copper alloys -Plate, sheet and circles for boilers, pressure vessels and hot water storage units" but that standard is not referenced from EN 13445. It also does not include CC333G.
The design pressure is 200bar. I understand that I will have to verify the strength of the part but before I get started I need to figure out if there is any chance that this can be inline with the 13445 code. I believe CC333G or similar copper-aluminium alloy are quite common as casing/house for seals and guides of rods in hydraulic cylinders. But I have not seen how reference to the material can be inline with EN 13445.
Question:
-Can it be possible to use CC333G in the hydraulic cylinder, even though there is no clear reference for this material in EN 13445? -How?
I appreciate any hint from you!
BR/Mihe
Question:
BR/Mihe
