Hello all,
Our company is about to receive a project for marine application condensers. We are at the R&D stage but can't figure out the best way to seal the tubes and tubesheet joints. Here are the information about the tube and tubesheets,
Copper-Nickel tubesheet (SB-171 70600) with two grooves inside holes
Copper Nickel tubes, 3/4"OD
The tubesheet has been designed per ASME VIII. Pressure is around 400PSI. The diameter is relatively small from 6" to 14".
Tubes are expanded by rolling. But apparently it does not seal tubes to tubesheet. re-expansion and changing the diameter of the holes did not help either. It looks to me that CuNi is too soft to be used as the tubesheet and with every expansion, the holes get deformed and a few leaks show up. Does anyone have any experience with CuNi tubesheet? Is it even possible to use it or we have to go for clad material? Or we have to weld?
Thank you.
Fred
Thank you.
Fred
