copy a point
mayrou
TN
hi!
I want to create a macro that copy a point
named "pt1" from an hybridbody1 to another hybridbody2
when i record a macro of this action:
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim partDocument1 As Document
Set partDocument1 = documents1.Item("387-181-953-0.CATPart")
Dim part11 As Part
Set part11 = partDocument1.Part
Dim hybridBodies11 As HybridBodies
Set hybridBodies11 = part11.HybridBodies
Dim hybridBody11 As HybridBody
Set hybridBody11 = hybridBodies11.Item("Construction maquette")
Dim hybridShapes11 As HybridShapes
Set hybridShapes11 = hybridBody11.HybridShapes
Dim zeroDimFeatVertexOrWireBoundaryMonoDimFeatVertex1 As Boundary
Set zeroDimFeatVertexOrWireBoundaryMonoDimFeatVertex1 = hybridShapes11.GetItem("pt1")
'selection1.AddzeroDimFeatVertexOrWireBoundaryMonoDimFeatVertex1
the problem here is that it works with selection! that make me upset!!!
help please! thank you
well copy and paste work with selection.
looking at your script: you Dim your zero[...]Vertex as Boundary and you set a "pt1" to it. I hope "pt1" is a a boundary feature.
Eric N.
hi
this macro may be useful for you!
it generate a copy of a point "point1" from an hybridbody1 named "construction" in part1 to the same hybrid body
Code:
Sub CATMain()
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Clear
Set partDocument1 = documents1.Item("part1.CATPart")
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Construction")
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapePointCenter1 As HybridShape
Set hybridShapePointCenter1 = hybridShapes1.Item("Point.1")
selection1.Add hybridShapePointCenter1
selection1.Copy
Dim partDocument2 As Document
Set partDocument2 = documents1.Item("part2.CATPart")
Dim part2 As Part
Set part2 = partDocument2.Part
Dim hybridBodies2 As HybridBodies
Set hybridBodies2 = part2.HybridBodies
Dim hybridBody2 As HybridBody
Set hybridBody2 = hybridBodies2.Item("Set géométrique.1")
selection1.Paste
part2.Update
End Sub
but i want to place the copy in an hybridbody2 named "set geometrique.1" in part2
thx :)))
selection1 was defined on active document (part1) when you do selection1.Paste you actually do part1.Paste !
check the very good [link ]GTWiki on this problem[/url] :
Also the point you copy is a center, don't you think you also need to copy the curve/circle needed for the definition of the point?
Unless you get the XYZ of part1.point1 and create (not copy/paste) a new XYZ point (not center) in part2.
Eric N.
I want a special paste as a result!
how can I do that?
if not there will be a problem with the update! the point is deactivated
check your online doc about selection... you should find your answer there
Eric N.
