Copy bodies from selected part bodies in product
yamaCad
Turkey
Hello all,
I'm trying a coding in vb.net
I select bodies - parts - and target part value from CATIA and adding into listview.
After that I'm planning selected bodies copying from parts and paste to target part.
But something is going wrong.
I tried search body names in selected parts. But not worked as well. Maybe cycle is better. Any idea?
I'm trying to make like this:
Here is my code:
Code:
Imports INFITF
Imports MECMOD
Imports PARTITF
Imports ProductStructureTypeLib
Imports System.Runtime.InteropServices
Imports System.Windows.Forms.VisualStyles.VisualStyleElement
Public Class Form1
    Private bodyToCopy As Body = Nothing
    Private targetProduct As Product = Nothing
    Private Sub copyBodyBtn_Click(sender As Object, e As EventArgs) Handles copyBodyBtn.Click
        Dim CATIA As Application
        Try
            CATIA = CType(Marshal.GetActiveObject("CATIA.Application"), Application)
        Catch ex As Exception
            MessageBox.Show("CATIA çalışmıyor. Lütfen başlatın.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Return
        End Try
        Dim productDoc As ProductDocument
        Try
            productDoc = CType(CATIA.ActiveDocument, ProductDocument)
            MessageBox.Show("Lütfen bir ProductDocument açın.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Return
        End Try
        Dim selection As Selection = productDoc.Selection
        Dim filter As Object() = {"Body"} ' Filter dizisini Object türüne dönüştür
        Dim status As String = selection.SelectElement3(filter, "Lütfen Body'leri seçin.", False, CATMultiSelectionMode.CATMultiSelTriggWhenUserValidatesSelection, False)
        If status <> "Normal" Then
            MessageBox.Show("Body seçimi iptal edildi.", "Bilgi", MessageBoxButtons.OK, MessageBoxIcon.Information)
            Return
        End If
        bodyList.Clear()
        bodyList.View = View.Details
        bodyList.Columns.Add("Body Name", 200) ' "Body Name" sütunu oluştur
        For i As Integer = 1 To selection.Count
            Dim body As Body = TryCast(selection.Item(i).Value, Body)
            If body IsNot Nothing Then
                Dim listItem As New ListViewItem(body.Name)
                bodyList.Items.Add(listItem)
            End If
        Next
    End Sub
    Private Sub partSelectBtn_Click(sender As Object, e As EventArgs) Handles partSelectBtn.Click
        Try
            Return
        End Try
        Try
            Return
        End Try
        Dim filter As Object() = {"Product"} ' Product için filtre
        Dim status As String = selection.SelectElement3(filter, "Lütfen Part'ları seçin.", False, CATMultiSelectionMode.CATMultiSelTriggWhenUserValidatesSelection, False)
            MessageBox.Show("Part seçimi iptal edildi.", "Bilgi", MessageBoxButtons.OK, MessageBoxIcon.Information)
            Return
        End If
        partsList.Clear()
        partsList.View = View.Details
        partsList.Columns.Add("Part Name", 200) ' "Part Name" sütunu oluştur
            Dim selectedProduct As Product = TryCast(selection.Item(i).Value, Product)
            If selectedProduct IsNot Nothing Then
                Dim listItem As New ListViewItem(selectedProduct.Name)
                partsList.Items.Add(listItem)
            End If
        Next
    End Sub
    Private Sub targetPart_Click(sender As Object, e As EventArgs) Handles targetPart.Click
        Try
            Return
        End Try
        Try
            Return
        End Try
        Dim filter As Object() = {"Product"} ' Filtre "Product" için
        Dim status As String = selection.SelectElement2(filter, "Lütfen bir hedef Part seçin.", False)
            Return
        End If
        Dim selectedProduct As Product = TryCast(selection.Item(1).Value, Product)
            targetList.Clear()
            targetList.View = View.Details
            targetList.Columns.Add("Target Part Name", 200) ' "Target Part Name" sütunu
            targetList.Items.Add(listItem)
            targetProduct = selectedProduct ' Hedef Part'ı kaydet
            MessageBox.Show($"Hedef Part seçildi: {selectedProduct.Name}", "Bilgi", MessageBoxButtons.OK, MessageBoxIcon.Information)
        Else
            MessageBox.Show("Geçersiz seçim yapıldı.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End If
    End Sub
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
    Try
        Return
    End Try
    Try
        Return
    End Try
    Dim rootProduct As Product = productDoc.Product
    ' Kullanıcıdan hedef Part ve kaynak Body seçimlerini doğrula
    Dim partAName As String = txtMainPart.Text.Trim()
    Dim bodyNames As String() = txtBody.Text.Trim().Split(New String() {Environment.NewLine}, StringSplitOptions.RemoveEmptyEntries)
    If String.IsNullOrWhiteSpace(partAName) OrElse bodyNames.Length = 0 Then
        MessageBox.Show("Lütfen hedef Part ve Body'leri seçin.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Return
    End If
    ' Hedef parçayı bul
    Dim partA As Part = Nothing
    Try
        For i As Integer = 1 To rootProduct.Products.Count
            Dim currentProduct As Product = rootProduct.Products.Item(i)
            If currentProduct.Name = partAName Then
                partA = CType(currentProduct.ReferenceProduct.Parent, PartDocument).Part
                Exit For
            End If
        Next
        If partA Is Nothing Then
            Throw New Exception("Hedef Part bulunamadı.")
        End If
        MessageBox.Show("Hedef Part bulunamadı: " & ex.Message, "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Return
    End Try
    ' Assembly ortamını kontrol et
    Dim designEnv As String = CATIA.GetWorkbenchId()
    If designEnv <> "Assembly" Then
        CATIA.StartWorkbench("Assembly")
    End If
    ' Body'leri tek tek işleme
    Try
        For Each bodyName In bodyNames
            Dim bodyA As Body = Nothing
            ' Kaynak Body'yi bul
                Try
                    Dim partB As Part = CType(currentProduct.ReferenceProduct.Parent, PartDocument).Part
                    bodyA = partB.Bodies.Item(bodyName)
                    Exit For
                Catch
                    ' Hata oluşursa bir sonraki ürüne geç
                End Try
            Next
            If bodyA Is Nothing Then
                MessageBox.Show($"Body '{bodyName}' bulunamadı.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Warning)
                Continue For
            End If
            ' Kopyalama ve yapıştırma işlemleri
            selection.Clear()
            selection.Add(bodyA)
            selection.Copy()
            selection.Clear()
            selection.Add(partA)
            selection.PasteSpecial("CATPrtResult")
        Next
        partA.Update()
        MessageBox.Show("Tüm Body'ler başarıyla kopyalandı ve hedef Part'a yapıştırıldı.", "Başarılı", MessageBoxButtons.OK, MessageBoxIcon.Information)
        MessageBox.Show("İşlem sırasında bir hata oluştu: " & ex.Message, "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
    End Try
End Sub
End Class
I updated the paste code but still have problem I select 4 parts. lets call it a.1 a.2 a.3 a.4 and TargetPart they have same named bodies. Result is like this: all bodies come from a.3 but I want like this:
a.1 -- body_a body_b body_c
a.2 --body_a body_b body_c
a.3 --body_a body_b body_c
a.4 --body_a body_b body_c
TargetPart --> body_a body_b body_c body_a body_b body_c body_a body_b body_c body_a body_b body_c
But my code give me like this :(
TargetPart --> body_c body_c body_c body_c body_c body_c body_c body_c body_c body_c body_c body_c
here is my latest code:
Code:
Try
    Return
End Try
Try
    Return
End Try
' Hedef Part'ı bulma
If targetList.Items.Count = 0 Then
    MessageBox.Show("Lütfen hedef Part'ı seçin.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
End If
Dim targetPartName As String = targetList.Items(0).Text
Dim targetPart As Part = Nothing
    If currentProduct.Name = targetPartName Then
        Try
            targetPart = CType(currentProduct.ReferenceProduct.Parent, PartDocument).Part
            MessageBox.Show($"Hedef Part '{targetPartName}' yüklenemedi. Detay: {ex.Message}", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Return
        End Try
        Exit For
    End If
Next
If targetPart Is Nothing Then
    MessageBox.Show("Hedef Part bulunamadı.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
End If
' Kaynak Part ve Body'leri kontrol etme
If partsList.Items.Count = 0 Then
    MessageBox.Show("Lütfen kaynak Part'ları seçin.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
End If
Dim sourcePartNames As List(Of String) = partsList.Items.Cast(Of ListViewItem).Select(Function(item) item.Text).ToList()
If bodyList.Items.Count = 0 Then
    MessageBox.Show("Lütfen kopyalanacak Body'leri seçin.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
End If
Dim bodyNames As List(Of String) = bodyList.Items.Cast(Of ListViewItem).Select(Function(item) item.Text).ToList()
Try
    ' Seçilen kaynak Part'ları işle
    For Each partName In sourcePartNames
        Dim sourcePart As Part = Nothing
        ' Kaynak Part'ı bul
            If currentProduct.Name = partName Then
                Try
                    sourcePart = CType(currentProduct.ReferenceProduct.Parent, PartDocument).Part
                    MessageBox.Show($"Kaynak Part '{partName}' yüklenemedi. Detay: {ex.Message}", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Warning)
                End Try
                Exit For
            End If
        Next
        If sourcePart Is Nothing Then
            MessageBox.Show($"Kaynak Part '{partName}' bulunamadı.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Warning)
            Continue For
        End If
        ' Seçilen Body'leri kopyala ve yapıştır
            Dim sourceBody As Body = Nothing
            Try
                sourceBody = sourcePart.Bodies.Item(bodyName)
                MessageBox.Show($"Body '{bodyName}' kaynak Part '{partName}' içinde bulunamadı.", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Warning)
                Continue For
            End Try
            ' Kopyalama işlemi
            selection.Clear()
            selection.Add(sourceBody)
            Try
                selection.Copy()
                MessageBox.Show($"Body '{bodyName}' kopyalanırken hata oluştu: {ex.Message}", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
                Continue For
            End Try
            ' Yapıştırma işlemi
            selection.Clear()
            selection.Add(targetPart)
            Try
                MessageBox.Show($"Body '{bodyName}' hedef Part'a yapıştırılırken hata oluştu: {ex.Message}", "Hata", MessageBoxButtons.OK, MessageBoxIcon.Error)
            End Try
        Next
    Next
    ' Hedef Part'ı güncelle
    targetPart.Update()
    MessageBox.Show("Seçilen Body'ler başarıyla hedef Part'a yapıştırıldı.", "Başarılı", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Try
What a mess.
Stop using names to identify products and source bodies, they should be placed to ListViewItem.Tag right after SelectElement.
Introduce standalone function CopyBodies(sourceParts as List<of Product>, bodyNames as List<of String>, targetParts as List<of Product>) that would
Code:
 For source in sourceParts
  For body in source.Bodies
    For name in bodyNames
      If body.Name = name then
        For target in targetParts
          sel.Clear
          sel.Add body
          sel.Copy
          sel.Clear
          sel.Add target
          sel.Paste
        Next
        Exit For
      End if
    Next
  Next
Next
What a mess.
Code:
          sel.Clear
          sel.Add body
          sel.Copy
          sel.Clear
          sel.Add target
          sel.Paste
        Next
        Exit For
      End if
    Next
  Next
Next
But code not works with same bodies. Parts are same, instances are different and my code only copies still the first part I choosed. Could you be more specific? I searched a bit and I find this metod so I need to define path everytime:
Function ReferenceToProductInstance(RootProduct As Product, _
ProductInstance As Product, _
PathToProduct As String) As Reference
Dim sProdName As String
Dim sPath As String
sProdName = ProductInstance.Name
sPath = PathToProduct & "/" & sProdName & "/!" & PathToProduct & "/" & sProdName & "/"
Set ReferenceToProductInstance = RootProduct.CreateReferenceFromName(sPath)
End Function
What a mess.
Code:
          sel.Clear
          sel.Add body
          sel.Copy
          sel.Clear
          sel.Add target
          sel.Paste
        Next
        Exit For
      End if
    Next
  Next
Next
That is shows what I wanted. Same parts with different instance. Select body for copying from selected parts. And finally that selected bodies paste into target part.
