Copy holes 1
sldwrksrobotics
20
Within the hole wizard is there a way to copy the sketch (construction lines with relations) for hole locations/pattern and paste to a second location?
You can copy the Sketch and paste it someplace else, but it is iffy since you will not have any relations.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
sldwrksrobotics,
I do not understand what you are trying to do and why. Are you trying to create multiple instances of a Hole Wizard hole? Are these holes on different planes?
If you provide more detail you are likely to get a great suggestion.
- - -Updraft
I would have liked to copy one fully defined pattern within the hole wizard to a second location. What I had to do was to duplicate the hole placement pattern and dimensions to a second location on the same plane.
You can create a pattern of the pattern, or 'Ctrl+C'/'Ctrl+V' in the sketch environment. If it's symmetrical, you could mirror it.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
You can copy and paste the sketch, but not in the wizard.
SW 2011 SP 2.0
Or copy and paste the feature and/or its pattern.
- - -Updraft
Updraft, thanks, never thought of doing that. Copied from one part to another, then rebuilt the relations.
SW 2011 SP 2.0
