Copy Paste all tables in a sheet
c_driver
Computer
Dec 20, 2019
1
I’m tasked with finding a way to copy all tables on a specific layer of a specific sheet, and then past them to the work-active sheet. As boilerplate I referenced for how to cycle threw all the tables, and modified that code to utilize cutcopypastebuilder. I'm uncertain if I am approaching this the best, any ideas? I’ve posted the code below, thanks!
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module2
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Sub Main()
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
'lw.WriteLine(workPart.FullPath)
'create list of layer numbers to Move tabular notes from
Dim tabularNoteLayerList As New List(Of Integer)
tabularNoteLayerList.Add(1)
'call sub to Move tabular notes
MoveTabularNotes(tabularNoteLayerList)
End Sub
Sub MoveTabularNotes(ByVal layerList As List(Of Integer))
Dim myTabNotes As New List(Of Annotations.TableSection)
Dim tmpTabNote As NXOpen.Tag = NXOpen.Tag.Null
Dim myTabNote As NXOpen.Annotations.TableSection
Dim type As Integer
Dim subtype As Integer
Do
theUfSession.Obj.CycleObjsInPart(workPart.Tag, UFConstants.UF_tabular_note_type, tmpTabNote)
If tmpTabNote = NXOpen.Tag.Null Then
Continue Do
End If
If tmpTabNote <> NXOpen.Tag.Null Then
theUfSession.Obj.AskTypeAndSubtype(tmpTabNote, type, subtype)
If subtype = UFConstants.UF_tabular_note_section_subtype Then
myTabNote = (Utilities.NXObjectManager.Get(tmpTabNote))
If layerList.Contains(myTabNote.Layer) Then
myTabNotes.Add(myTabNote)
End If
End If
End If
Loop Until tmpTabNote = NXOpen.Tag.Null
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Move Tables")
'Dim nErrs1 As Integer
'nErrs1 = theSession.UpdateManager.AddToDeleteList(myTabNotes.ToArray)
Dim cutCopyPasteBuilder1 As Drafting.CutCopyPasteBuilder
cutCopyPasteBuilder1 = workPart.DraftingManager.CreateCutCopyPasteBuilder()
cutCopyPasteBuilder1.DestinationView = workPart.Views.WorkView
Dim nErrs1 As Boolean
nErrs1 = cutCopyPasteBuilder1.ObjectsToCopy.Add(myTabNotes.ToArray)
cutCopyPasteBuilder1.Transform.Option = GeometricUtilities.ModlMotion.Options.None
cutCopyPasteBuilder1.InitPaste()
Dim nXObject2 As NXObject
nXObject2 = cutCopyPasteBuilder1.Commit()
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId1)
End Sub
End Module
