Hi all!
I'm trying to code macro which would copy bodies from all parts and instances in assembly (1st level) and paste them (as result) in newly created part in same assembly.
Problem is that if I do the same thing manually, positions of fasted bodies are as in source part or instance, if I macro does it, positions of bodies form source are ok, but from instances are not.
I guess it should be pasted "in context", but how to do this with macro?
Code:
Sub CATMain()
Dim RootProduct As Product
Set RootProduct = CATIA.ActiveDocument.Product
'first check if document is part or product
If InStr(CATIA.ActiveDocument.name, ".CATProduct") < 1 Then
MsgBox RootProduct.name & " NOT Assembly!"
Exit Sub
End If
' count of parts and instances to use
Dim PartsCount As Integer
PartsCount = RootProduct.Products.Count
Debug.Print "Total numbers of parts:"; PartsCount
'Enter name of new Part and name it
Dim newPartName As String
newPartName = InputBox("Enter name for new part.")
Dim newPart As Product
Set newPart = RootProduct.Products.AddNewComponent("Part", newPartName) 'create part to paste bodies in it
Dim targetPart As Part
Set targetPart = newPart.ReferenceProduct.Parent.Part
' loop trough parts
Dim BodyCount As Integer
Dim oPart As Part
Dim curentBody As body
Dim selectedEL As Selection
Set selectedEL = CATIA.ActiveDocument.Selection
Dim k As Integer
Dim rndNo As Integer
Dim m As Integer 'counter for pasted bodies
m = 2
' loop trough parts and instances
For i = 1 To PartsCount
Set oPart = RootProduct.Products.Item(i).ReferenceProduct.Parent.Part
' Debug.Print oPart.name
BodyCount = oPart.Bodies.Count
' Debug.Print BodyCount
' loop trough bodies
For k = 1 To BodyCount
Set curentBody = oPart.Bodies.Item(k)
If curentBody.Shapes.Count > 0 Then 'check if body is empty
selectedEL.Clear
selectedEL.Add curentBody
selectedEL.Copy
selectedEL.Clear
selectedEL.Add targetPart
selectedEL.PasteSpecial ("CATPrtResultWithOutLink")
selectedEL.Clear
rndNo = (10000 * Rnd) 'generate random number for pasted body renaming
targetPart.Bodies.Item(m).name = targetPart.Bodies.Item(m).name & rndNo
m = m + 1
Else
Debug.Print curentBody.name & " is empty!"
End If
' Debug.Print curentBody.name
Next
Next
Debug.Print m ' number of pasted bodies
newPart.Update
End Sub
