Copy Section 1
macduff
1,255
Stupid question. can I copy a section? I need to make an additional section a-a for a paint, chem film and anodizing processing and do not want in the original sec a-a where the dimensions are going to be.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Not that I know of.
Are you wanting to do this on the same sheet as the parent and original section view?
One workaround;
Copy the parent view and use the same section line to create a new section view, and then either hide the parent view or move it outside the sheet area.
CBL, the workaround will work just fine. Yes, it's on the same sheet.
Thanks amigo!
Mechanical Designer
