0.125pLL
- Jul 11, 2019
- 8
Hello!
How do I get correct axial loads for RC column design from a flat slab (irregular column layout) FEA model? I've come to a conclusion that for the design of the slab itself, in ULS (Ultimate Limit State - EC), it's acceptable to get slab internal forces using uncracked slab stiffness. But to get the correct column axial loads I should crack the flat slab?
