I have a skirt where the bottom few inches have rusted out, and the plan is to cut the bottom 6" out in segments to replace it. My first instinct was to CJP it all around, like-for-like, from the outside so that no one is welding in confined space. However, this skirt is 3/8" thick by 18'-0" diameter, and I'm concerned about weld distortion.
So, what should I be concerned with, welding inside confined space or weld distortion?
Also, I'm thinking about providing this single weld pass PJP as an alternate. I'm not sure if a j-groove can be done on a curved surface, but this would be ideal.
