CloudNine1
- May 20, 2018
- 14
Hi all,
I'm working on a project that comprises of building a heat exchanger.
The fluid inside the heat exchanger is sea water (with some algae, but let's ignore that for our matter) at 350 celsius degrees and 250 bar (I'm trying to perform HTL - hydrothermal liquefaction, hence the high pressure).
I've been surfing the web all day (including combing through various standards like ASME B31.3 and TEMA) trying to find which corrosion allowance should I take when calculating the pipe's wall thickness, but I couldn't find any decisive answer.
The pipes' material that I chose to use is Stainless Steel 304L, which, as far as I know, pretty much resistant to corrosion. But can I completely ignore this corrosion factor? I doubt that...
I know that there's an official formula to calculate the corrosion factor, but I don't know what values to plug in it as well...
The heat exchanger will eventually be built, this is ain't a theoretical work, thus I need to be 100% sure of all of my calculations.
Another detail that you need to know: it is a laboratory-scale heat exchanger, so the flow in it will be quite little and short-timed, mainly to see if the HTL process was done successfully.
Would appreciate any of your help!
P.S I also bumped into a few related threads from this very forum, but it didn't really help.
Thanks!
Thanks!
