Hi everyone,
I'm currently indagating aspects related to plating racks structure.
At this moment I'm looking for a solution or something that can help to find a precise answer to this trouble:
To make possible the coupling of a copper flat bar to the stainlessteel clips we need to use zinc plated bolts.
Practically, holes are drilled and threaded in the copper flat bar and clips are mounted using zinc plated bolts.
The problem is: We can notice, where the bolt is coupled with copper, an abrupt reduction in section of the bolt.
Consider this situation: The final structure is insulated with PVC coating, immerged in an acid solution at 55°C and a continous cathodic current flow is applied.
We can suppose the bolted joint isn't in contact with oxygen because of PVC coating, so I'm going to indagate stray current corrosion. I should be a good idea or not?
If anyone can help me I'd be very grateful.
Luigi
Luigi
