Corrosion rated of uncoated steel
71corvette
105
Can anyone provide generally accepted anticipated rates of corrosion for uncoated steel exposed to the elements? I realize the rates of corrosion will vary based on a myriad of environmental criteria, but are there some basic ranges of corrosion rates that can be provided?
Thanks,
Tim
In a typical environment corrosion rates have been determined at: 0.008in/yr.
In more corrosive environments rates extend to 0.012in/yr.
You can find this information in many FHWA or NCHRP references.
Qshake
[pipe]
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
