In EN 13195,it is specified that aluminum alloys supplied in the H116 or H321 temper in the form of sheet, strip and plate shall be subjected to exfoliation corrosion test and intergranular corrosion test. For H112 aluminum alloys supplied in the Otemper H111temper H112 temper, no corrosion test is specified. It is to be discussed that why corrosion test is not necessary for aluminum alloys plates in the temper( such as O temper, H111 temper and H112 temper).
