We have found high concentrations of H2S (800 - 1400ppm) in our system were the pH is 7. We are injecting 100% of sea water on the whellhead which could be causing this high values of pH. I have calculate the partial pressure of H2S and it is greater than 0.05psi (maximun pH2S before SSC could happen according to Nace standars)
I would be interested in any advice you could provide on the suitability of sour corrosion for vessels and piping upstream.
Thanks for any input.
