Corrosion
Chembloke99
Chemical
AU
I am a recently graduated chemical engineer, working in an oil and gas firm . I would like to know how I can I annual calculate corrosion rate for oil and gas pipeline? for one case, fluid contains both C02 and H2S. for other case the fluid contains just C02. the overall fluid is mixed phase. Can anyone send me a link for corrosion estimation model or spreadsheet. any help would be greatly appreciated.
You need to use a more descriptive subject title.
How much historical test and corrosion data do you have to work with? Any corrosion monitors or sensors in your system?
Plymouth Tube
Thanks you all for your help. I really appreciate it.
