Bammer25
- Mar 22, 2018
- 149
Hi again gents. My extent of timber post design has been limited mostly to decks, so I just use a basic simpson strong tie post base. No big deal. But what about when you have decent loads you want to spread out? I am not seeing a lot out there outside of me just designing a custom base plate with flaps that bolt up to the sides of the post.
Another one: what about a knee brace into a beam and/or column. Not seeing much out there other than a basic simpson piece that has very low capacity. I thought about using tension cables, but again, not entirely sure the best way to connect them.
Any tips from some of you more experienced wood guys?
