Hi All,
We are going to have coupling Transformer for Static var generator and the Voltage Ratio is 220/33 kV. I have come across OEM GTP HV -LV Impedance is around 25% , is any specific reason for SVG application Impedance should be Greater than 25%. what will be the difference in construction of Transformer with reference to the conventional transformer.
Thankyou.
Thankyou.
