John1967778
Hi Guys,
Looking at an unreinforced brickwork wall which has stepped cracking approximately 7mm-8mm along it. I've been recommended to use a product known as helifix to essentially 'stitch' up the brickwork. It is basically high strength steel bars installed across the crack. My question is; whats wrong with just traditional re-pointing/patching the crack? I understand that these reinforcing bars will essentially hold the wall together across the crack at a much stronger rate than traditional repointing but what does it matter if the cause of the cracking/movement to the wall is prevented. IF anyone has any experience with using these steel bars then i'd much appreciate your input. Thanks!
