Creating an Array and Finding the Smallest Value
jzecha
Aerospace
So I am creating an optimized Bounding Box for my company based on some of the other codes I have found and have run into a problem.
I have created multiple bounding boxes and created a Parameter for each boxes' volume.
I have then used those Parameters to try and create an Array that I want to go through and find the smallest volume which would be the smallest Bounding Box.
A couple questions I have:
How do I count the number of Parameters in the Parameter Set?
Every result I have gotten also includes Parameters from the part design itself.
The bigger question, I struggle with the recursive i functions.
Can someone help me out with a way to go through all the parameters and find the smallest value?
Here is the section of code I am working on:
Code:
 Dim strParam10 As StrParam
    Set strParam10 = oParameter.Item("Inertia_Bounding_Box 0 Degrees")
    Dim strParam11 As StrParam
    Set strParam11 = oParameter.Item("Inertia_Bounding_Box 10 Degrees")
    Dim strParam12 As StrParam
    Set strParam12 = oParameter.Item("Inertia_Bounding_Box 20 Degrees")
    Dim strParam13 As StrParam
    Set strParam13 = oParameter.Item("Inertia_Bounding_Box 30 Degrees")
    Dim strParam14 As StrParam
    Set strParam14 = oParameter.Item("Inertia_Bounding_Box 40 Degrees")
    Dim strParam15 As StrParam
    Set strParam15 = oParameter.Item("Inertia_Bounding_Box 50 Degrees")
    Dim strParam16 As StrParam
    Set strParam16 = oParameter.Item("Inertia_Bounding_Box 60 Degrees")
    Dim strParam17 As StrParam
    Set strParam17 = oParameter.Item("Inertia_Bounding_Box 70 Degrees")
    Dim strParam18 As StrParam
    Set strParam18 = oParameter.Item("Inertia_Bounding_Box 80 Degrees")
    'MsgBox strParam17.Value
    'MsgBox ("Parameter Count " & oParameter.Count)
    'selection1.Search "CATKnowledgeSearch.InternalParameter.Name=*Inertia_Bounding_Box*,all"
    Dim BoundingBoxVolumes(8) As Double
    SmallestVolume(0) = (strParam10.Value)
    SmallestVolume(1) = (strParam11.Value)
    SmallestVolume(2) = (strParam12.Value)
    SmallestVolume(3) = (strParam13.Value)
    SmallestVolume(4) = (strParam14.Value)
    SmallestVolume(5) = (strParam15.Value)
    SmallestVolume(6) = (strParam16.Value)
    SmallestVolume(7) = (strParam17.Value)
    SmallestVolume(8) = (strParam18.Value)
No recursion here, just a loop:
Code:
Dim values, value, i, smallest
Set components = CreateObject("System.Collections.ArrayList")
For i=0 to 8
  value = oParameter.Item("Inertia_Bounding_Box " & i*10 & " degrees").Value
  values.Add value
  If IsEmpty(smallest) then
    smallest = value
  ElseIf value < smallest then
    smallest = value
  End If
Next
Post your full code to get advice on "count parameters in Parameter Set" as I don't quite understand what you mean. In most cases Parameters.SubList(feature, false) filters direct parameters related to the feature.
