Hi all.
Please advise on methods available.
Given:
Assembly (large weldment) with multiple components. I need to make fab drawing at this assembly level for fab.
Drawing method:
Drawing will be abo 10 sheets long. I want to create drawings in the order which it will be fabed. That means.
Sheet 1 will have multiple views with 3 components (the rest need to be hidden) because these are first components welded together.
Sheet 2 will have original plus 3 more components.
sheet 3 will have all of the above + the next 5 components.
Each sheet will have top and side view and a other details or cross sections as necessary.
Questions:
Is there a method to hide selected components in modeling view and maybe save that view/configuration so that when I create base view and other projected views it will show only desired components on that sheet.
For the next sheet maybe i can save a different view with different hide/show configuration.
I tried:
I know there are "hide components in view" and I have used it in the drafting. however, when I have to go back and add a view or project a view I have to run the "hide component in view" command again for the newly added view.
Working in NX 10
Given:
Drawing method:
Questions:
I tried:
Working in NX 10
