Creating Plane 1
yamaCad
Turkey
I'm trying create a plane from selected axis but I'm missing something so It can' create it. I record a macro for this but it takes like axis2 how can I get my axis selected? Because I'm not work with main axis. After selecting axis macro will create plane from selected axis. Or can start from xy direction or z direction of selected axis.
Recorded is like this:
Code:
Language="VBSCRIPT"
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim axisSystem1
' No resolution found for the object axisSystem1...
Set reference1 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(AxisSystem.2;1);None:();Cf11:());WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", axisSystem1)
Set hybridShapePlaneOffset1 = hybridShapeFactory1.AddNewPlaneOffset(reference1, 20.000000, False)
Set hybridBodies1 = part1.HybridBodies
Set hybridBody1 = hybridBodies1.Item("kesme_celigi")
hybridBody1.AppendHybridShape hybridShapePlaneOffset1
part1.InWorkObject = hybridShapePlaneOffset1
part1.Update
End Sub
Here is my code:
Code:
Sub CATMain()
    Dim partDoc
    Set partDoc = CATIA.ActiveDocument
    Dim part
    Set part = partDoc.Part
    Dim hsf
    Set hsf = part.HybridBodies
    Dim geomSet
    Set geomSet = hsf.Add()
    geomSet.Name = "kesme_celigi"
    Dim selection
    Set selection = partDoc.Selection
    MsgBox "select axis"
    Dim status
    status = selection.SelectElement2(Array("AnyObject"), "select", False)
    If status = "Normal" Then
        Dim selectedAxis
        Set selectedAxis = selection.Item(1).Value
        If TypeName(selectedAxis) = "AxisSystem" Then
            Dim factory
            Set factory = part.HybridShapeFactory
            Dim xyPlane
            Set xyPlane = factory.AddNewPlaneExplicit(selectedAxis.GetItem("XY Plane"))
            geomSet.AppendHybridShape xyPlane
            part.Update
        Else
        End If
    Else
        MsgBox "selection canceled"
    End If
End Sub
this code assumes you have already selected your AxisSystem. I retrieve all the info from this axis system (origo, axis coordinates) and create two lines that will span the plane.
Code:
Sub CATMain()
Dim partDocument1 As partDocument
Dim part1 As part
Set part1 = partDocument1.part
Dim hybridShapeFactory1 As HybridShapeFactory
Dim sel
Set sel = CATIA.ActiveDocument.Selection
Dim axiscoord(2)
Dim originCoord(2)
Dim axissyst
Set axissyst = sel.item(1).Value
Dim originpoint, hybridShapeD1, hybridShapeD2, hybridShapeD3
axissyst.GetOrigin originCoord
Set originpoint = hybridShapeFactory1.AddNewPointCoord(originCoord(0), originCoord(1), originCoord(2))
axissyst.GetXAxis axiscoord
Set hybridShapeD1 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
axissyst.GetYAxis axiscoord
Set hybridShapeD2 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
axissyst.GetZAxis axiscoord
Set hybridShapeD3 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
Dim Plane_line_1 As HybridShapeLinePtDir
Set Plane_line_1 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD1, 0, 10, False)
Dim Plane_line_2 As HybridShapeLinePtDir
Set Plane_line_2 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD2, 0, 10, False)
Dim myXYPlane As Plane
Set myXYPlane = hybridShapeFactory1.AddNewPlane2Lines(Plane_line_1, Plane_line_2)
part1.HybridBodies.item(3).AppendHybridShape myXYPlane
part1.UpdateObject myXYPlane
End Sub
Code:
Sub CATMain()
Dim part1 As part
Dim sel
Dim axiscoord(2)
Dim originCoord(2)
Dim axissyst
End Sub
Thank you Lwolf Now I'm at work I will try tonight. Is this possible from selecting of my custom axis xy_plane. In your code are you select axis or plane?
Code:
Sub CATMain()
Dim part1 As part
Dim sel
Dim axiscoord(2)
Dim originCoord(2)
Dim axissyst
End Sub
Hello LWolf.
Your code didn't worked on me I think because of my version. It's R21.
But I get the idea and I changed a little bit.
Here is my code and it works perfectly.
Thank you :)
Code:
Sub CATMain()
    Dim partDocument1
    Dim part1
    Dim sel
    Dim status
    status = sel.SelectElement2(Array("AxisSystem"), "Select an axis", False)
    If status <> "Normal" Then
        MsgBox "Axis not selected. Macro canceled."
        Exit Sub
    End If
    Dim axissyst
    Set axissyst = sel.Item(1).Value
    Dim axiscoord(2)
    Dim originCoord(2)
    Dim originpoint
    Dim hybridShapeD1
    Dim hybridShapeD2
    Dim hybridShapeD3
    Set originpoint = hybridShapeFactory1.AddNewPointCoord(originCoord(0)-0.5, originCoord(1), originCoord(2))
    Dim Plane_line_1
    Dim Plane_line_2
    Set Plane_line_1 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD1, 0, 1, False)
    Set Plane_line_2 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD2, 0, 1, False)
    Dim myXYPlane
    Dim targetHybridBody
    If part1.HybridBodies.Count = 0 Then
        Set targetHybridBody = part1.HybridBodies.Add()
        targetHybridBody.Name = "YeniHybridBody"
    Else
        Set targetHybridBody = part1.HybridBodies.Item(1)
    End If
    targetHybridBody.AppendHybridShape myXYPlane
End Sub
