Creating the Hole with Existing Point
BarathAlagar
10
I want to create the hole with existing point. when try to CommitFeature it gives the error like "A Sketch was expected but not found"
please refer below code in C#,
HolePackage Hole_Feat = (NXOpen.Features.HolePackage)holePackageBuilder1.CommitFeature();
Note: The error get capture in try catch and The hole is getting created in NX. But not able to get the holePackage through CommitFeature.
To be honest, I am unsure what you are describing, but since nobody has answered I will take a shot in the dark for you.
Is it possible you are creating the points using a sketch feature and not creating a regular point or something? Or maybe when creating the point you have associative checked?
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
It may work best if you create a new sketch for the hole and make the point in the sketch coincident to the existing point.
Jerry J.
UGV5-NX1899
