Crop view
Coboco
Industrial
Feb 14, 2007
6
Is it possible to crop view in drawig... in INV11?
What do you mean by 'crop view'? You only want to show part of it?
yes only the part of it... not all part
Create the view on a second sheet. Then, create a 'Detail View' of the area you want to show (turn off the labels for the view.) Once you have the area showing what you want, drag the the view in the tree up to the 1st page.
Also, edit the 2nd sheet and exclude from count & printing.
that is exactly what I did... but unfortunatly there is no better way, I guess :(
You could also make a view representation in your part/assmbly. Then when you insert the view you can select that representation and it'll display the same. If the part/assembly needs to be sectioned, then you could 'Slice' the part.
