For Clause 13.3.3.1, the code states that to calculate the compressive resistance of angles as follows that 3 conditions must be met.
One of those conditions is "members are loaded at the ends in compression through the same one leg".
Does that mean that I can only have that angle that's in compression connected via welding through a single leg or can both be welded.
Did not find the commentary for this section useful at all in answering this question.
