Can ASTM A53 or A106 pipe be used in accordance with CSA s16?
CSA S16 calls out for structural material to be either CSA G40.20/21 or ASTM A992. I find it hard to believe that ASTM pipe isn't used regularly for stanchion and similar applications in the oil & gas industry. Any ideas? Am I off base with my assumption? Do the designers lean on the "unidentified steel" paragraph for this use case?
thanks
thanks
